13 f150 ecoboost groan behind glovebox at starting speeds
1000-1500 rpm i have a slight groan sound coming from the glove box area, seems to get louder the colder it gets
is there a pump maybe a mechanical pump or vacume pump in that are that can make noise??
It might be the brake vacuum pump.
any other ideas?
The vacuum pump on a 2013 is run off the camshaft on the rear passenger side. It is actuated by a cam lobe there. It could be your issue.
