285/75r17 of 285/70r17?
Hey guys I need some help deciding on a tire size. My truck is a '14, 5.0, 4x4 with 3.55s. I'm adding Raptor wheels and looking at 285/75r17 and 285/70r17. My stock tires are 275/65r18, 32.1" tall and weigh about 51lbs each. The 285/75 are 33.9" tall and 63lbs each. The 285/70 are 32.8" tall and 57lbs each. I want a bigger tire but I don't want to loose a lot of power or mpg. I also don't want to regear my truck (did that with my '05 5.4 with 315s). Will the 285/75 be a big difference in power and mpg? I'm afraid the 285/70 isn't going to look much different than what I have now. Any experience or info would be appreciated. Thanks.
Hey, I was in the same spot. I ended up wanting to go with the 75 series tires for the added height. Unfortunately I'm up in Canuckistan and they didn't have that size available yet in the tire I wanted. I ended up going with the 285/70/17 and am quite happy. Not too much of a knock on mpg's and no real difference in power (you can notice it a bit, but pretty comparable to the 20's and 275's I had on previously).
I'm running a 2" level on the front and the rear sits almost an inch higher than stock with the addition of the AAL.
Here's what it looks like. I don't think the tires look too small.
Thanks, that helps! I am actually adding those Raptor wheels to my truck and those are the exact tires I am considering. A benefit of the 285/70 is the Nitto Ridgegrappler has a C rated tire. Most of the aggressive ATs in 285/75 are all E rated tires. This is my truck I'm adding the Raptor wheels to. I have added tint and a low profile matte black tool box since this photo.
Thanks again. I'm probably going with the 70s in the ridge grapplers. BTW, your truck looks good!
Got the tires and wheels installed over the weekend. The wheels didn't come with the SVT center caps so those and a set of black lug nuts are on order. I am really happy with the setup and glad I didn't go with the larger size. Sure they would have looked a little better but now I get to keep my MPG.
285/70’s
Your thread helped out a lot on me deciding what size tire to go with. Appreciate the comments and photos. 2011 F-150 with Fox 2.0 coils and powder coated raptor wheels (Gloss Black).
Before mods. Still not sold on the steps I replaced the chrome ones with.
