Shudder and Whine diagnosis
Hello! This is my first post to this forum. The issue I am having is a loud whining noise that seems to be originating from the rear of my truck. I also note that my truck turns roughly to either side as if it is stuck in four wheel drive. I checked the four wheel drive system and it is functioning properly which leads me to believe this might be related to the rear differential. I am unsure how to properly diagnose the differential.
Originally Posted by eyeman76
(Post 5194841)
Originally Posted by RSTHD150
(Post 5194950)
Bet the clutch packs are blown in the rear diff.
(Post 5194986)
I was concerned that someone would bring that up. Seems to be a pretty common problem with these trucks.
Depending on how much $$ they want to replace your clutch packs...I'd consider replacing the whole carrier with an Eaton TrueTrac. No more clutches to replace. http://www.ebay.com/itm/Eaton-Detroi...lV~BpO&vxp=mtr |
Originally Posted by NASSTY
(Post 5194992)
On the 2011's and newer it's hard to find a L/S diff. Most of the newer trucks have an open diff. w/ an optional an E-locker.
Give the modifier more time to work itself into the clutches - if it doesn't go away in a couple weeks, put another tube of modifier in.
(Post 5194992)
(Post 5195308)
So I changed my differential fluid and used Royal Purple with one 4oz tube of Ford friction reducer. About 90% of the symptoms have gone away, but they are still there. Thoughts?
(Post 5195327)
Every 4x4 has the ls, not so uncommon.
(Post 5195327)
Starting in 2012 the LS was phased out. |
