Vent To Atmosphere Best 2 bucks i have spent
Funny thing about it is i have provoked 2 races since yesterday just letting them blowoff. Before i had a hard time getting anyone to play, as soon as they heard the turbo's they would back off
Then get under the front of the truck and undo 3 of the finger screws to access the bottom of the intercooler, pull that back and you will see the bottom of this pipe. Just turn the ends about a half a turn to the left to get it off
Not sure how much truth there is to that but would make sense.
Just started running the 93 MPT tune also and that really wakes the truck up, i thought the 91 did a great job. This 93 Perf tune flat out screams
From what I remember the 11-12 trucks use a different layout for the diverter valves/recirc circuit. If you have one of them it will be a little bit different.
The reason for the diverter valves is to prevent compressor surge when you lift off the throttle. There is an amount of compressed air between the compressor wheel on the turbo and the butterfly valve. When you let off the throttle the butterfly valve closes and basically plugs up this pipe. This pressurized air has to go somewhere so it either backs up into the turbo and can cause compressor surge, it can be dumped into the atmosphere or it can be piped away from the butterfly valve and back to the turbo inlet side. The third option is the most efficient since it's using air that's already in the system but number 2 sounds cooler.
You take off this piece at the bottom of the intake (where i capped off with the rubber piece)
Attachment 4247
Attachment 4247
