5.0 Coolant Leak - T connector
Looks like I've got the same/similar leak with that dang T connector.
Here's what it looks like running... You can see the drips in the first 5 seconds.
I saw the other thread about it but I think mine is leaking at the other side.
http://www.ebay.com/itm/BRAND-NEW-OEM-THERMOSTAT-HOUSING-T-CONNECTOR-2011-2013-FORD-F-150-MUSTANG-/331485379210?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d2e117a8a&vxp=mtr
In this picture, it would be off the left side of the highlighted yellow portion based on what I've seen. And I see no gasket listed. Am I stuck buying the whole assembly?
Thoughts?
Thoughts?
http://www.tascaparts.com/ford/f-150...pper-hose-seal
Looks like it's the upper hose seal.
Because that elbow on the upper hose...
http://www.tascaparts.com/ford/f-150...ame=upper-hose
...Connects to that T junction.
2014 f150 v8 5.0 coolant leak
Hi all
today I noticed that my truck sounded different, there was a small noise like a grinding noise coming from the engine compartment, when I opened the hood I also noticed that under the rad hose by engine it was wet, also reservoir was empty. took 2 jugs to fill it,
Any help would be appreciated
Hi all
