SuperCab door rattle
Having picked up my newly-purchased '14 SuperCab from the dealer to fix a rattle in the driver-side half-door, the rattle is still there though not as bad. As far as I can tell it is at the top latch.
Realizing that the half-door doesn't have a pillar/post to anchor on, is the rattle something I should live with? Is this not an uncommon problem with the SuperCab? Do other SuperCab owners have the same problem and can it be cured?
Because of the rattle, I'm wondering if I made a mistake and not getting another SuperCrew.
I also surprised at the lack of response to my question. Either we don't have many SuperCab owners or they don't have a problem with the doors.
In any case, thanx for the reply. Gonna try to get the dealer to solve it.
After owning 5 SuperCabs, a 2000, (2) 2003's. a 2006 and now a 2013 Lariat. I can say that every one of them would rattle if you didn't slam the doors hard! Just close them really hard and you shouldn't hear any rattles. I personally would stay away from the dealer as this is a common thing and they will probably just make it worse.
That sucks to hear, as I've been looking at a 14' FX4 supercab as my next truck. When I look at it this weekend I will double check when I shut the doors. I know on my last truck, gmc sierra ext cab sometimes if I didn't close it hard enough I would get a slight rattle or air noise, then I would just slam it harder, well right before I sold it I slammed it too hard and the door was stuck, never did figure it out and the guy that bought it didn't care and was going to try to fix it himself.
No rattles on my 13 SuperCab.. I don't have to slam the doors or anything.. Just normal open and close..
No rattle on my 97 SuperCab either... It only had the passenger opening door, but it never rattled..
I don't think it's "normal" at all... Probably just some adjustment to the latch or something??
Good luck!
Mitch
Good luck!
Mitch
