Sliding Rear Window defog contacts
#46
I am having the same problem with my rear window, but am out of warranty now. Window opens and closes but dash light for defrost is inop but the heated mirrors seem to work ( I think ). Where are these contacts and can you bend them back into place so it will work again ? I just wont open the window anymore. 2011 F150XLT Supercab 4x4 5.0 with Chrome pkg. 40k.
#47
F4E,
Contact prongs are behind the black piece on the sliding window itself....4 I believe. Those contact a flat plate on the entire window when closed to close the loop. I opened my window a few inches and checked it out with a flashlight a while back so I'm going off memory. Mine were dirty so I slid a micro fiber cloth with sprayed on contact cleaner and gently slid it back and forth to clean the prongs and I removed some gunk . It looks like one could actually remove the black piece off the window for more thorough cleaning. Now the flat contact piece on the solid window, I left that alone right now since it's hard to get at so I need a different strategy for that. I never had any problems with the system but I like my heated mirrors on foggy damp mornings where I live or I cant see crap....especially the driver one with the film on it that tints at night. It's a safety issue.
#49
#51
I am having to go back for this issue on my 2013 Supercrew.
The first repair was to simply replace the switch in the dash for the rear defrost. That's what my dealer stated was the issue.
Having re-found this thread, I hope they don't try that boneheaded repair again, and go ahead with replacing the rear window. It seems like I have the exact same symptoms as most in this thread.
Here's to hoping my dealer doesn't screw around with me again. I'm well under warranty mileage (30,9xx), so Ford will pay them.
It really makes it hard to enjoy my Ford truck when Ford's dealership network does the bare minimum during services. Ugh.
#52
Hi BigTRQ,
I want to do what I can to help resolve this issue for good. Send me a PM with your full name, best daytime phone number, VIN, current mileage, and servicing dealership. I'm on the case!
Crystal
Crystal
#53
#54
It might be a good idea to get a second opinion from a different Ford Dealership. Find some local options by entering your ZIP code here: http://www.ford.com/dealerships/locate What's the current mileage on your truck?
Crystal
#55
Just tried my rear window defrost this week and the light came on for just a sec and then goes out. Checked fuses and looks OK. Could it be the relay? If I open and close the power slider, once and a while it will light the bulb for a sec…but not every time. My '13 Lariat just crossed the 60k mark...
#57
My 2012 rear window defroster quit
My rear defroster quit too and had 2 dealerships tell me no they can't fix it under ESP. I bought what I thought would cover it from them but they said no even though the warrenty says heater is covered. Sucks you buy something thinking you will have no problems and do after spending quite a bit of money with them .
#58
I have the Ford Extended warranty,and it has written in black and white, "HEATED BACK GLASS". (I have the premium coverage, check your plan) I was dealing with a Lincoln dealership (closest to my office) for work. It took some info from Ford customer service here to talk with people at the ford warranty authorization center, and a phone call back to the dealership to set them straight. Check the brochure you were given when you purchased your warranty.
#59
I replied to your PM. Please check your inbox when you get a chance.
Thanks for the mention, and for sharing your story along with the resolution.
Have a great day, and we will be here if you need us!
Tricia
