Sponsored by: DashLynx
Who has the most miles on their EcoBoost?
Old 07-03-2014, 05:32 PM
Wookie's Avatar
Originally Posted by PawPaw
With almost 5K miles on my Eco engine it already has doubled the miles when I had an engine problem with the 5.0 in my '11...that proves the Eco is more durable!
Ohh damn! This place is about to go full retard now!
  #32
Old 07-03-2014, 05:38 PM
All of you need to do the BOV VTA mod and an offroad down pipe whenever you decide warranties are unneeded! With those done, them turbos will whistle like crazy, and THAT I could start to enjoy.
  #33
Old 07-03-2014, 06:28 PM
  #34
Old 07-03-2014, 10:01 PM
wfburton159's Avatar
My dad was driving a 2011 EB for work that had over 70k. He was driving in heavy rain on interstate and the condensation deal happened to him. Lost power and after it dried out was back to normal. The rear end was howling as well and the pinion bearing was bad. There was shavings in the oil so the dealer changed all the bearings in the rear end. So I bought a 5.0
  #35
Old 07-03-2014, 10:50 PM
NASSTY's Avatar
So the 5.0 rear end is different from an Ecoboost rear end?
  #36
Old 07-03-2014, 11:51 PM
Wookie's Avatar
Yup, it can be weaker since it doesn't have to deal with so much torque!
  #37
Old 07-06-2014, 08:51 PM
crazynip's Avatar
Originally Posted by MitchF150
crazynip.. Have you changed the plugs in your rig yet?? Have fun with that!
Mitch
Changed them 4 times... myself
And I can drive my truck in high humidity conditions without it blowing up too
How many Ebs do you own or have you owned? Since you seem like you know what your talking about.. Oh wait, typical EB hater
Zero... not hater, just think that dinky turbo engines belong in euro station wagons, not trucks
So, anyone got one over 100k yet?
  #38
Old 07-17-2016, 09:29 PM
Buckrodgers's Avatar
222000 klms
I have 222000 klms. Original motor turbos everything. Suspension was totally redone and brakes ect. Had to do plugs 4 times now and did the weep hole mod on the intercooler. Best mod was the weep hole! Not a issue since then, 80000 klms ago. Oh cats are plugged now but just delete and go with a tune.
  #39
Old 07-18-2016, 04:53 PM
NASSTY's Avatar
There's a guy on ecoboost.net with over 300,000 miles on a 2011.
  #40
Old 07-18-2016, 06:10 PM
26K on my Ecoboost with no problems...even has the original plugs!!
  #41
Old 08-18-2016, 07:16 PM
Golfmanaz1's Avatar
2011 EB with 171,000. Normal maintenance of fluids, belts, hoses and brakes. Plugs at 50k, 100k, 150k. Plugs are easy after 1st time, just lube up the boots well. Running strong at 19.2 mpg average. Had a 05 Screw that was running great at 251k when it got totaled in accident.
  #42
Old 06-14-2018, 02:11 AM
Eric Wallentine's Avatar
2013 F150 EB - 165,000+ miles: $450 repairs. Love it!
Originally Posted by lariatf150
i've read about problems related to misfires while driving in very humid or moist conditions and it was related to the charge air cooler getting too much moisture inside. But i realize there was also a plug change and gap on the plug change also. I also read about potential carbon build up on a couple of specific intake valves where the pcv valve empties its gases into the intake. The thought on the carbon issue is because it's direct injected and the fuel does not spray on the valves to clean them all the time.
Anyway, i realize by asking a discussion forum we will get only a tiny tiny percentage of answers from 3.5l ecoboost owners because the vast majority of f150 owners will never join a discussion forum like this. But i was just curious who has high mileage and has not experienced these problems on 2014 four 2013 models. I would like to keep my truck for at least 10 years or maybe 12.
My truck is a 2014 built in april. It has the latest charge air cooler and tune from the factory.
000
  #43
Old 06-22-2018, 07:18 PM
Golfmanaz1's Avatar
246k miles. Changed plugs every 50k. At 200k changed coils. Water pump and starter around 200k. No other issues. Don't really have to worry about moisture issues here in Arizona.
  #44
Old 08-21-2023, 06:34 PM
Golfmanaz1's Avatar
2011 Ecoboost high mileage currently 450k on 8/21/23
Update on my high mileage 2011 F150 Ecoboost currently 450k on 8/21/23.
Synthetic blend and Motorcraft filter changes from 5k-10k depending when I have time. Water pump at 200k, transmission at 353k (had a used tranny and flex plate put in for $2000), AC compressor at 410k. Plugs every 50k, coils every 100k, brakes (great use of lifetime warranty pads from Autozone) hoses, and belts as needed. Struts and upper arms at 300k, driver side lower ball joint around 330k. Original motor and turbos. Never had a alignment. Never changed rear differential fluid yet. A couple starters (one under Autozone warranty), 1 - O2 sensor, rear shocks once. Passenger valve cover (one of the spark plugs oil seals went bad in the cover). Pegasus Auto Racing Silicone hose kit for coolant tank. A bunch of windhshelds (Arizona rocks all over the roads). Not sure how may sets of tires. There is minor oil seepage, but no major oil leaks, no spots in garage. Blower motor. Power wire going to driver window motor went bad in the harness at door hinge area, so just ran another power wire to get it running instead of replacing harness or trying to repair wire. Hoping to make it to 500k. Forgot to add have NOT replaced cam phasers or timing chain. It as been making cam phaser noise for 200k but not sure if I want to sink $2500-$3000 for cam phasers/timing chain and water pump job.
The following users liked this post:
  #45
Old 08-21-2023, 06:37 PM
Simply amazing. Nice work!
Try to get it to 1 million miles.
May I ask, why do you drive so much?
Quick Reply: Who has the most miles on their EcoBoost?
