Water stain in headliner
Just noticed this yesterday:
The same staining is located on both pass and driver rear corners. I do have a sunroof but pretty sure it doesn't leak however did leave it open over night about 1 month ago and as luck would have it, it snowed that night. Was able to shop vac the snow because it was cold enough not to melt it but maybe some snow got into the gap between the roof and sunroof with it being open.
The high 3rd brake light was replaced with a smoked lense witch came with a nice thick gasket so I don't think any water gets in through there.
Its too cold to do any water testing now but I do want to try and remove these stains, any recommendations what use for cleaning it?
I had the tsb done for the third brake light leaking on my 10 a few years ago.Not thinking, I later bought a tinted third brake light from a member on here about year ago. Soon after I noticed water leaking by the back window and a stain in the headliner, it was the third brake light seal, even had water in the light. The seal had pulled away from the light where it was glued, I RTV'd it, no problems now, just need to get the stain out.
That's exactly what it is - carpet and upholstery. Use an extractor device - a Little Green Machine or a carpet extractor that also has a wand for upholstery. It will apply, scrub, and extract.
When i took the light off I could see water in the channel under it leading to the stain.Not to mention the water in the light and the messed up seal. I haven't cleaned the stain yet though.
There is a TSB (12-4-4) for cleaning the stain. Seeing that you changed your light assembly, I'm sure your not covered but maybe you can try the procedure yourself. But then again, I have no clue if what they suggested in the TSB actually works. It says to use Motorcraft Professional Strength Carpet and Upholstery Cleaner ZC-54.
Makes me wonder if Ford will fix this annoying and 10 year old/ongoing issue with the 15's. I bet not.
