Ecoboost safety features- limp mode, etc
What engine parameters are monitored by the pcm for the ecoboost engine? Tranny temp, coolant, etc?
What about EGT's? I tow quite often and would like to know if the EGT is monitored. If not who makes and aftermarket gauge and probe for the ecoboost?
there are not many things monitored which are displayed in the message center and or gauges..
I have a EDGE CTS, which ive updated and was once in my 09 5.4
I think true coolant temp, tranny temp, and Head temp are good things to watch. there are other things like boost also you can monitor. you can set thresh holds also and get an alert when reached.
I can tell you I have had the head temp climb by 15 degrees, long before the coolant temp moved at all under towing conditions however it was still safe..
ill look up a few more of the PID's that I can pickup with the latest update from EDGE. and re-post
If you have a smart phone you can get the Torque app from andriod market for $4.99. Then all you need is a blue tooth adapter that plugs in under the dash for around $20.00 either from Ebay or Amazon.com. I have it and it works great!
http://www.androidauthority.com/torq...th-obd2-95772/
AeroForce scan guage, ROUSH dash vent guage pod with Autometer angle ring.
Monitored parameters/functions .....
01. INTAKE AIR- Intake Air Temperature
02. INTAKE AIR TEMP. 2 (intercooled applications)
03. COOLANT TEMP- Engine Coolant Temperature
04. TRANS TEMP 1- Transmission Temperature (gas powered automatics)
05. TRANS TEMP 2- Transmission Temperature. Can be used if Trans Temp 1 is not supported.
06. RPM- engine Revolutions Per Minute
07. MAF SENSOR LB/M- Mass Air Flow (lbs/min)
08. MAF COUNTS- Mass Air Flow sensor raw output in counts
09. FUEL LEVEL – 0-100 %
10. MANIFOLD PSI- Manifold Air Pressure (psi)
11. THROTTLE POS PCT- Throttle Position percentage (0-100%). Will typically read around 10-90%.
12. PEDAL POSITION – Similar to Throttle pos. but is rescaled to read the full 0-100 range.
13. MILES PER HOUR- Miles Per Hour
14. KNOCK RETARD- Knock Retard (degrees) 4.6L 4v non-SC’ed
15. IGNITION ADVANCE- ignition timing advance
16. SHORT TRIM B1-short term fuel trim bank#1
17. SHORT TRIM B2-short term fuel trim bank#2
18. LONG TRIM B1-long term fuel trim bank#1
19. LONG TRIM B2-long term fuel trim bank#2
20. OXYGEN SENSOR B1-O2 bank 1 sensor in millivolts
21. OXYGEN SENSOR B2-O2 bank 2 sensor in millivolts
22. BATTERY VOLTAGE- Alternator/battery output voltage
23. ENGINE LOAD-calculated Engine Load (0-100%)
24. FUEL PRESSURE
25. FUEL PUMP DUTY CYCLE
26. CYLINDER HEAD TEMPERATURE
27. OIL TEMPERATURE – not widely supported on Fords.
28. Calculated Engine Torque (Auto trans)
29. TRANS SLIP 1 - Transmission slip for most 2005/2006 vehicles
30. TRANS SLIP 2 – Transmission slip for some 2007+ vehicles
31. TRANS SLIP 3 – Transmission slip for some 2007+ vehicles, mainly trucks.
30. Current Gear – current transmission gear
31. Miles Per Gallon – instantaneous fuel economy
32. Calculated net horsepower
33. FUEL STATUS – Displays “Open” or “Closed” to indicate open or closed loop fueling.
34. Analog 1 – analog input #1
35. Analog 2 – analog input #2
24. FUEL PRESSURE
Does it show boost levels along with the temps?
Do you use it when towing?
I clicked on your link... I would think it would be nice to set it up with boost and all the temps so you can watch while towing in the hills to make sure nothing is getting too hot. Might be worth the 25 bucks to know if you are having a problem and pull over before something goes wrong
Perty much several pages of different things. If U purchase a Code reader that reads in real time and plug it in U will get an education and have some fun navigating all the live running graphs and such that it can provide while U drive around enjoying the truck. After a while U can save the info to look at sometime in the future when U have a problem with UR truck.
