Rear end whine! Anyone fixed rear end on 2011+
Hey Power Kid, How is your 2011 running otherwise?
Did you ever go in for any of those EB TSB's or the new intercooler?
Is the pinion bearing included in this?
Transmission: all internal parts, clutch cover, seals and gaskets, torque
converter, transfer case (including all internal parts), transmission case,
transmission mounts; Front-Wheel Drive: axle shafts, bearings (front
and rear), center support bearing, drive shafts, final drive housing
(including all internal parts), hubs-automatic front locking (four-wheel
drive), locking rings (four-wheel drive), seals and gaskets, universal and
constant velocity joints; Rear-Wheel Drive: axle shafts, bearings (front
and rear), center support bearing, drive axle housing (including all
internal parts), drive shaft, propeller shafts, retainers, supports, seals and
gaskets, universal and constant velocity joints.
http://www.lombardfordwarrantys.com/...11Warranty.pdf
