Door key pad arm/disarm alarm?
I've had my FX4 for 3 yrs now and never used the door keypad to lock or unlock.
I have the 6 button, dealer installed (gold seiers?) key fob alarm and would like to know if I lock/arm the system with the key fob will the alarm be triggered if I unlock using the door key pad?
If you DON'T have the code....
Ford used to put a sticker on the computer with the code of the keypad on it. Look for a marker/sticker with 5 numbers on it on the main cpu under the dash area. I haven't looked for one on your model year truck but its your best shot, otherwise you go to the dealer service dept.
HTH
If that (#3/4 key) is also the key to enter the last digit of the code then that's what I meant. Maybe I wasn't clear. If that is not the key to used to enter the last digit of the code then there is a difference between yours and the systems I am familiar with (02' and 13'). Was your code stuck to your computer?
Thanks for that info. I've learned something today. Both of my vehicles (02' Lightning and 13' SuperCrew) have required me to enter the last digit of the code a second time to unlock remaining doors.
Formula that's the way it is supposed to work, the #3/4 button pressed right after you enter the code will unlock all 4 doors. Was that way on my '05, '09, & '13. To clarify, I'm referring to the FACTORY alarm, not a dealer installed alarm system. My GF had the Ford dealer installed alarm and it was different, kind of "quirky" fsr...
