Anyone's brake controller not working?
I hooked up my toy hauler yesterday, and the brake controller doesn't activate the brakes. When I try to manually activate them the info screen just reads trailer disconnected. I checked the fuse and seems okay, so not sure. Anyone else experience this?
The controller needs to be paired to the trucks module. The dealer can do it, Cha Ching....
another way for them to take your money...............nuts......... |
Originally Posted by aussiekeeper
(Post 4987710)
If it's the factory controller and it came with the truck when it was new, there's no reason why it shouldn't work unless you have a bad relay or fuse or a broken wire. The only time you have to pair the controller to the truck is if it didn't come with it and you add it.
Yep, factory brake controller. Fuse is installed and looks good. Looks like she's going back to the dealer. :(
It's probably just a bad connection at the trailer plug. Clean it up and try it again (both truck and trailer sides).
Eliminate the trailer
Make sure it is the truck and not the trailer that's causing the problem. If you have a friend who has a truck w/brake controller, have him hook up to your trailer to make sure the trailer is not the problem.
Originally Posted by Harley Rider
(Post 4987954)
I know it's not the trailer. Brakes work on my Tacoma with Prodigy and my Dad's GMC 1 Ton. Brand new truck, so connections look clean and good.
On the way to work I got stuck in traffic. I messed with the onscreen settings and I think I found the issue. In the menu you can select what type of brakes the trailer has. Electric or Electric with Hydraulic. From the factory it's set for Electric. I think my trailer has Electric/Hydraulic though. So, when I get a chance to go out to the trailer storage yard, I'll hook up and see. :) I'll report back later. |
Not many trailers have electric Hydraulic brakes it is a expensive option that does not work with all brake controllers. I bought my 09 used it had never towed a trailer 1st time I hooked a trailer up no trailer brakes. Popped the hood missing a relay and 2 fuses opened the glove box there they were in a bag with a Brake controller harness. Installed fuses and relay trailer brakes work great. I have seen the same thing on customer vehicles the factory tosses the harness and fuses and relays in the glove box even on trucks with built in controllers.
Originally Posted by 1mainiac
(Post 4988086)
I'm not going to the trailer tonight to see if the new Electric / Hydraulic setting works due to the storms in the Midwest. But, I will report back after I do. :) I'm not sure what type of brakes I have, but I'm going to find out. |
Well, I just spoke to the owner of the company who sells my toy hauler. He confirmed my brakes are electric. So, I guess the factory setting of the brake controller should have worked. Looks like she's going back to the dealer to troubleshoot. :(
Dealer looked at my truck. Vedict is....... "We don't know what's wrong." Great, let's cancel my 2nd camping trip now. I'm freaking bummed. :( Now they say can you bring it back next Thursday with the trailer? Geeeez! Rant off....:)
As I said before, check the trailer plugs. Even though they are new on the truck side, there have been others who had to lightly clean them with emery cloth or fine sand paper so the trailer would be recognized. Brand new trucks too. Either the contacts inside are not sprung out enough, or maybe there is a sealant on the brass, but that might be your issue. It's worth a try.
Originally Posted by Ford850
(Post 4989182)
I'll crawl around this weekend trying everything i know to try and what you recommend. If I can't get it, I'll drop her off at Etrailer, and let them troubleshoot. I really don't want to leave my truck and trailer with the Ford dealer at this point. |
| All times are GMT -4. The time now is 10:51 AM. |
