F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2009 - 2014 F-150 (https://www.f150online.com/forums/2009-2014-f-150-105/)
-   -   Proper wheel for 11'FX4 (https://www.f150online.com/forums/2009-2014-f-150/455139-proper-wheel-11fx4.html)
4thf150 Aug 18, 2011 08:56 AM
I am having a tough time finding the correct info and wanna order my wheels soon! I would like to put the **** Cepek DC-2 wheels on my 11' FX4, its gonna have a 4" Rancho lift and I'm gonna go with the 35/12.50 Nitto Trail Grapler's. My question is can I run a 18" wheel with this setup? What would you guys go with, 18 or 19"? Thanks!
http://i255.photobucket.com/albums/h...laten37/dc.jpg
4thf150 Aug 18, 2011 09:38 AM
Ok, I just spoke with Rancho and they recommend a 4.5 backspace...however DC only makes this wheel in a 5" backspace. How much of a difference is this gonna make? Also, I need a 6x135 bolt pattern, correct? Thanks again!
SkiDood Aug 18, 2011 10:04 PM
No problem with that backspacing. I'm running an 18x9 +18mm offset which is about a 5.75" backspace (assuming you're talking about a 9" wheel).
brazzeal15 Aug 18, 2011 11:27 PM
Yes you need a 6x135 bolt pattern, and with a 4" lift you can fit those wheels. Should look great! I had those wheels on 3 of my trucks, and I am considering them for my 2010. Post some pics when your done with it!
4thf150 Aug 19, 2011 09:39 AM
Rancho is telling me they are not if 5' backspace will work and they might rub. They are not positive since they only tested the 4.5 backspace. Another question I have is what does a 1/2 difference on backspace due to the appearance of how the wheels and tires look, does it make them stick out farther or tuck under the wheel well more?
