F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2009 - 2014 F-150 (https://www.f150online.com/forums/2009-2014-f-150-105/)
-   -   XD's for my FX4 (https://www.f150online.com/forums/2009-2014-f-150/448128-xds-my-fx4.html)
BLUEforLIFE May 2, 2011 08:25 PM
XD's for my FX4
Guys, did a quick photoshop. do these look good on my truck.
XD monsters with nitto terra's 305.55.20
What size is the lug pattern? The retard at my dealership is a total ass, he's useless.
thanks
[IMG]https://www.f150online.com/forums/me...0-xdwheels.jpg[/IMG]
Trizzot May 2, 2011 08:43 PM
I believe the lugs are 6x135.
Langford May 2, 2011 08:45 PM
6x135 is correct, and if you get the wheels with a +35mm offset, you can clear 33x12.50's with no rubbing on stock suspension.
fx4 for life 79 May 2, 2011 08:54 PM
Check my truck out. I've got those wheels with the same color truck
BLUEforLIFE May 2, 2011 08:59 PM
does the +35 stick out past the flares? I was thinking the +18
do you have any other pics?
thanks, looks good.
fordfx4guy May 2, 2011 08:59 PM
Take a look at the XD Addicts
only saw your profile shot, do you have other pics
thanks bro
BLUEforLIFE May 2, 2011 09:05 PM
just did, still like the monsters better. thanks for the suggestion though.
As popular as these are I havent seen them on anybody's truck here in NJ.
Langford May 2, 2011 09:07 PM
thanks, looks good.
The +35 sticks out a bit, but not super far...but far enough to look good IMO. I wanted the +18, but they wouldn't work with 33's without either a lift or a bit of trimming...which I didn't want to do. The best pic I have right now is in my sig, if you click that you can see it better...but I don't have any other good ones right now, sorry.
BLUEforLIFE May 2, 2011 09:13 PM
so the +18 would keep them tucked in more but you would have to trim the valence, is that correct? I rather not cut anything also, guess i should go with the + 35. Im also going with the terra grapplers, so you think they would rub with the +18.
BTW, what is the BS of your wheels
thanks bro
06yz250f May 2, 2011 09:47 PM
i did that exact photoshop on my truck (same as yours) a few weeks back
saying that, don't do monster because i am :lol:
rich_platinum May 2, 2011 09:49 PM
Here's my truck with +14. Tires are LT305/55r20. Not the same qheels youre looking at though. Come out to 33x12.5 i have a leveling kit up front. No rub anywhere. Hope this helps a bit. I love how they extend out the wells, not a while lot but just enough.
https://www.f150online.com/forums/me...re-profile.jpg
05BlackFX4 May 2, 2011 09:55 PM
Looks awesome.
I have the 20x9 with +18 offset with 6.13BS I believe..would have to check on the backspace. Go with the +18 offset. Both DarrenWS6, MBlouir, myself and a few others have the same setup. They cleare with 33x12.5x20 (305/55/20) and a 2" level. No rubbing and come close to the control arms. Check out Darren's pictures as he has some better ones than me for clearance.
so to recap...+18 will look better IMO but you will need either bilstein 5100s or a 2" leveling kit (about $60 + alignment)
+35 will work on stock suspension but stick out a little further
lugs are 6x135 :beers:
fx4 for life 79 May 2, 2011 11:10 PM
thanks bro
Check my album
Langford May 3, 2011 03:17 PM
thanks bro
It is actually the opposite. A +18 will stick out further from the fenders, the +35 tucks into the truck more. With the +18, you will have to either lift or trim to make the 33's fit because they stick out further and will rub the bumper when you turn. The +35 tucks in further, and will clear 33x12.5's with NO spacer, lift, or trimming.
With the +35mm, the tire is close to the upper control arm, but it doesn't rub at all. I wouldn't have believed that 33's would fit with 0 rubbing with the +35 mm offset without seeing it...but they work. A buddy of mine has 20" XD Hoss wheels with a +30mm offset and 33" Toyo MT's on a 2011 Fx4, and his clears just fine too.
The wheels I originally wanted were only available in a 0 offset, or +18...but they wouldn't clear the 33's without the front lift. I wanted to stay away from lifting the front at all because I HATE the dog scratching its @ss look, and I will be towing a lot with this truck...so a front lift wasn't an option.
