Air Bag Light
Air Bag Light
2010 Platinum and since day one have had the airbag light come on at randome times. It resets when you turn off the truck and may or may not come on for an hour or 2 or not until the next day. Had it into the dealer with the light on ond it was a short in the Pass side. They took it all apart and reset all connections and checked the whole system out and found nothing. Picked it up after the dealer having it 2 days and @3 hours latter on came the light. How many times do I give them to fix it before I pull the pin on the lemon law. Any Ideas?
Yes, the yellow airbag light. I got mine into the dealer with the light on and they found some type of short in the pass side airbag system. Trouble shoot for 2 days no fix light still comes on randomly. Been on vacation for 2 weeks and had the light on a lot. back to the dealer on Monday. Tired of driving a Focus.
same thing with my 09 plat. i have right at 47k on it now. started around 13K on truck. and i have extended warranty so further investigation should be no problem.
they replaced the whole lower seat tract. was a 1K part from supplier. wow.
was fine for a thousand miles or so . then came. on .. at random
then went away again. now about three times a month it comes on.. going to let them know i want something filed with Ford. .
this is crazy.
this is crazy.
http://news.yahoo.com/s/nm/us_ford_recall
recall issued for around 1.2 million ford trucks. hopefully this will solve my issue as well.
missed the years. i had someone call me to make sure i knew about it. just went to link and posted..! from what a couple ford garages have told me , im not the only one in the quad city area here in illiinois having issues with the stupid airbag light. im thinking there are more to follow.
i shut off the easy entry feature in my truck the day i got it. so i know its not an issue there with all the wires moving around each time i get in the truck. im sure it would have been fine until the day its out of warranty. then there would be some pig puff of smoke!!
light came on yesterday after work. shut truck off. and then started backup . was fine for the ride home.
i have always thought it was a module that either did not power off, power off correctly or did not 'boot' as it should . if all the modules dont talk to each other correctly this issue can happen.
well. lets home they find out whats going on with our model years.
