305/55r20 Hankook Dynapro - will they rub on stock 20's?
hey guys,
i have a 2010 white lariat f150 4x4, s-crew, with stock 18's. Im wanting to sell the 18's, by some platinum OEM 20's, and put on a 2 inch AS leveling kit, along with 305/55r20 Hankook tires Question: Does anyone have personal experience with these tires - set up? will they rub at all?? (control arm, sway bar, etc) I've seen one platinum with this set up and he said no rub, is the platinum and lariat have the same suspension set up? Right now my 18's are about 1 inch away from the control arm, and i'm just worried, if i change the wheels and tires, it will rub with a wider tire. any help and pics would be good. tks |
I had to go from 2 inch pro comp kit to a 1 inch daystar kit because sometimes control arm would hit spring making right turns weird? now I run one inch level kit and 285/60/20 with no problems.
2" level and stock 20s with 305/55/20 your fine. I got that setup with nitto trail grap mt
Yes
colonel blue,
do you have any pictures? also, opinion?- what stocks look better?- 20 inch lariat stocks or 20 inch platiunum stocks on a white truck? tks |
| All times are GMT -4. The time now is 07:58 AM. |
