Which rear block do I need?
The vehicle is a 2010 FX4. I currently have a HBS 2" leveling kit installed and want to put a 2.5 inch block in the back (the AS 3 inch will be to much rear lift). I found some pro comp blocks online but im not sure which one I need. They have different pin sizes ranging from 9/16, 5/8, and 3/4. Here is a link to the ones that I found: http://www.4wheelparts.com/Lift-Kits...8in.%29_PQ=2.5. So which one do I need?
anyone?? Im sure someone on here has one of the Pro Comp kits.
If no one answers you, later today I will measure the size on the ones I removed and post the size for you......
why will the 3" blocks be too much? i have them on my truck with the 2" front and it sits level.
http://farm2.static.flickr.com/1214/...ba7b5741_b.jpg |
Originally Posted by dubsesd
(Post 4396326)
Stock platinum 20's with 305/55/20 hankooks
My 2010 XLT, 4x4 has 3/4 inch pins. One male and one female in the center of each cast iron block. My 2004 truck may of had smaller ones??
Originally Posted by J T Ford
(Post 4396312)
Where are you guys getting your autospring blocks from?
Originally Posted by marshal
(Post 4396587)
Can anyone confirm they are 3/4 inch? |
dont mean to hijack, but would an add-a-leaf be better then a rear block if I was going to haul my ATV in the back. I sit level now,(bilstein 5100s) but when I put my sportsman 500 in it, i am nose high.
yes, i'm getting ready to buy an add-a-leaf too.. a block will lift it up, but add a leaf will give you... ANOTHER leaf for a little added strength agains sagging and lift you up a little bit.
let me know where you get yours from
(Post 4396326)
