Ford's "build and price" website, is it real?
I am looking to replace my 2005 (lemon) in the next year or so and thought I would go through the online process of building my ideal vehicle to see approx. what the MSRP would be.
Some things completely perplex me. For instance Standard cab: XL (2wd) 4.6 3v engine $5265 option 5.4 engine $4010 option Standard cab: XLT (2wd) 4.6 3v engine $4790 option 5.4 engine $4505 option Supercab: XL (2wd) 4.6 3v engine $4040 option 5.4 engine $4010 option Supercab: XLT (2wd) 4.6 2v engine NOT OFFERED ???? 4.6 3v engine Standard (3.73 rear end not avalable for this engine?) 5.4 engine $795 option Supercrew: XL (2wd) 4.6 3v engine $3960 option 5.4 engine NOT AVAILABLE Supecrew: XLT (2wd) 4.6 2v engine NOT OFFERED ???? 4.6 3v engine standard 5.4 engine $795 3.73 limited slip not available? I drove myself nuts trying to figure this out. There seems to be no rhyme or reason why certain engines are not available based on TRIM level. I could understand wheelbase differences or cab differences to not make certain drivetrain packages available, but this is rediculous. Case in point, I was trying to price an XLT Supercab with 6.5 bed, 4.6 2v engine and a 3.73 limited slip and apparently cant. But they make it in XL trim... So there is no technical reason they cant. Also what is with the 5.4 engine being a cheaper option than the 4.6 3v engine? Is this just a website bug or is this how Ford custom build vehicles are now? I used to always order vehicles from the factory but had not the last 2 trucks I have bought (2005 and 2001) so it may have changed, but it used to be that you could pretty much do anything you wanted a-la carte. |
The build price is a little confusing at times. Try again because your numbers seem a little off.
For example, you have: Standard cab: XL (2wd) 4.6 3v engine $5265 option 5.4 engine $4010 option I have: $5265. and $6110. The 4.6L 2V is the lowest level engine with a 4 speed so it makes more sense to use it for the lower trim level and not the XLT which is 2 levels above the XL and more of a mid range model. |
So basically you can't get the 3.73 LSD with the 4.6 3V, you're stuck with the 3.55 LSD. And you can't get the 4.6L 2V with the supercab.
You can get an XLT supercab with 6.5' bed, 4.6 3V engine, and 3.55 LSD. I agree with you that it's lame you can't get your desired configuration in an XLT, only an XL. I don't see the 5.4L being cheaper than the 4.6 3V. It shows it as a $795 upgrade for me with the above configuration. |
Originally Posted by statikuz
(Post 4062834)
You can get an XLT supercab with 6.5' bed, 4.6 3V engine, and 3.55 LSD. I agree with you that it's lame you can't get your desired configuration in an XLT, only an XL. It is a sweet combo but it is odd that it is only available with 4WD. It was VERY hard to find but I lucked out by finding one locally with all the other options I wanted and almost none of the options I didn't. Of course it took over a year as I was originally looking at '09's. The option combos do not make any sense to me either except to the degree that I understand Ford is trying to simplify the production lines to a certain degree. But some of the combinations are completely backwards. For example, IMO the 4.6L 3V with 6-speed is the optimum off-road engine considering that it is over 100 lbs. less weight up front and has considerably more range in the back-country due to it's more efficient idle and is more efficient all around but particularly when just tooling along slowly as one is apt to do when in the back-country or especially in 4-low. But sometimes selecting 4WD requires the 5.4L engine and the Raptor is not even available with the 4.6L 3V which would be a sweet combo for a truck designed to go fast over rough terrain. But my question to the original poster, why are you set on the 5.4L engine if you can get the configuration you want with the 4.6L 3V and 6-speed tranny? |
I gotta say thats pretty sweet though. I wish I could get a truck to my exact specifications because basically all I want is a basic truck with a few extras ya know?
You'll have to add a fuel expense, mine was about 90, and the advertisement fee, which I think was about 400
Originally Posted by Real
(Post 4062967)
The 2V 4.6L/4-spd combo sucks. It is cheaper, but I see no reason to get it. The 3V 4.6L/6-spd is significantly quicker and gets better fuel economy. As to why the various prices and disparities comes from the forcing you to "upgrade" to larger cab or 4wd, or some other package The 5.4L has historically been less than $600 extra over the 4.6L, all else equal, and in 2009/10 this is over the 3V 4.6L. |
(Post 4062967)
Originally Posted by APT
(Post 4063666)
That's it. Manufacturing complexity costs a lot of extra money. Compare "building" any Honda vs. the F-150.
Originally Posted by crazynip
(Post 4063919)
...it cant be that much of a better engine over the 2v engine.
I'm curious if either A) you've driven any 2009+ F-150 with the 6-spd or B) you've read about such complaints on here. Your concerns should quickly be verified or relieved with one test drive. I suspect that you will find no issue with transmission hunting. Besides, smaller gear ratio spacing means the annoyance if there is hunting is lowered due to the engine speed not changing as much between gear shifts. ...they are all just built, and they take one off the rack and put it off the truck. |
| All times are GMT -4. The time now is 10:11 PM. |
