Gotts Mod 2010 f150
Old Dec 14, 2009 | 08:26 AM
Edwardsfan99's Avatar
Gotts Mod 2010 f150
Has anyone tried the Gotts mod on a 2010 yet - 5.4l? Was going to buy a CAI but having read this would rather do the Gotts mod and a programmer?
Old Jan 30, 2010 | 06:19 PM
JOHNWSC's Avatar
No,but I'm anxious to see if someone has also.if so please post it.
Old Jan 30, 2010 | 07:18 PM
Real's Avatar
2009 and 2010 come with a cold air intake from the factory. It's hard for me to see how it could be improved upon significantly.
Old Jan 30, 2010 | 11:44 PM
redfx4150's Avatar
Removing the air snorkel is the best thing that can be done And it cost nothing for 7hp
Old Jan 31, 2010 | 10:12 AM
GS357's Avatar
Has anyone removed the snorkle and installed a drop in K&N? This would be very easy if you really get something out of it. (and cheap)
Old Jan 31, 2010 | 01:15 PM
Real's Avatar
K&N 'filters' let too much abrasive road grit through for my liking. Oiled or not, they do not filter as well as a well made fiber filter and in most applications do not remove enough air-flow restriction to matter. This is more true than ever on late model vehicles.
IMO, the most over-hyped product around.
But there will always be staunch supporters of the product just because it is something to buy to 'distinguish' one's truck from a stock machine. But it is not better than stock, worse actually.
Old Jan 31, 2010 | 07:35 PM
#16F150's Avatar
I have removed the snorkel and installed and installed a AFE Pro Dry S drop in...
Old Jan 31, 2010 | 08:20 PM
Dizman's Avatar
I did the mod (snorkel removal) but did not disconnect the battery yet to get the supposed full effect. All I really notice so far is a little more noise when the throttle is applied.
Also, there is no way to connect a piece of tubing to the air box, as the hole left in it is a very odd shape, sort of triangular.
Old Jan 31, 2010 | 08:59 PM
White Platinum's Avatar
Any pics or instructions on how to do this mod to a 2010? Why does the battery have to be disconnected? I do have a Justin custom tune on my truck will this help or is pointless?
Old Jan 31, 2010 | 10:17 PM
Dizman's Avatar
Supposedly, the computer will learn the new increased air flow and will adjust the fuel rate to keep the air/fuel ratio correct.
All you have to do is remove the airbox and squeeze the heck out of it to get the snorkel piece out of the box. I used 2 small screwdrivers to pry it out as I could not squeeze the cold plastic enough to get it out, otherwise. You are then left with a much larger hole in the air box and a rubber flap leading into the inner fender area.
Old Jan 31, 2010 | 10:49 PM
statikuz's Avatar
Removing the snorkel is pointless, it certainly doesn't give you a magical 7 HP. Some people said it made the truck sound better so I pried it off for grins, but it mostly just made an annoying resonating at certain RPM so back on it went.
Old Jan 31, 2010 | 11:00 PM
Burncycle's Avatar
Stop Talking.
https://www.f150online.com/forums/20...ts-2009-a.html
Old Jan 31, 2010 | 11:54 PM
MarkY's Avatar
+1. K&N = for Kooks and Nuts
Old Feb 1, 2010 | 12:00 AM
statikuz's Avatar
Originally Posted by Burncycle
My Bad Bro.
Let me rephrase:
Better? I guess to me the 2% HP increase at high RPM wasn't worth the droning to me, but it may be to others.
Old Feb 1, 2010 | 02:37 AM
Burncycle's Avatar
Hey now I'm not one to argue with free horsepower but to each their own. I have yet to do it to know if there is any droning and can understand that when you buy a 30k truck you don't want it to be annoying to drive haha! And I didn't mean to seem malicious in that post. The land rover forums have put me in a crabby mood >_<
