Leveling kit issues
Old Jan 4, 2023 | 06:08 AM
Kbfishingfool's Avatar
Leveling kit issues
Ok out new spacers 2 in aluminum all bolted up fine can get the spindle to the upper control arm together re did the entire front end steering rack pump all new lines to re bushing the lower control arms and replacing ball joints etc only thing thats different is kyb struts do I bust out the strut shock compressing tool ? Haven't been able to solve the misfire until I get it back together thank in advanced
Old Jan 5, 2023 | 11:44 AM
Yes, you'll need to need to use a spring compressor. Just please be careful using them. Make sure you use the safety wire. Don't stand on either side of it when working on it too just in case.
What are the codes for the misfire? What is the engine type?
