2007 F150 V6 runs rough
I cannot get more than 3k rpm, replaced plug wires and plugs. Anyone know anything to help?
It sounds like your cats are plugged.
I'm sure you've got a check engine light on... even if it isn't see if there are any pending or confirmed codes. If you don't have an OBDII scanner, most major auto parts stores will let you use theirs... |
Here you go.
Here are some parts if you need cats. Search a little more on your own, and you will find more options with different pricing and availability. You may not need CARB compliant EO no., depending upon where you live. PART # 545355https://services.magnaflow.com/Image...ges/545355.png
PART # 52154https://services.magnaflow.com/Image...ages/52154.png
PART # 52155https://services.magnaflow.com/Image...ages/52155.png
a little late but check out the intake runner manifold control
again a little google fu on the subject will bring up tons of info on it lots of vids on google tube as well |
