2006 F-150 Lariat, low beams out, high beams good
Very recently the low beams on my 2006 F-150 Lariat stopped working. I do have some after market LED's in place. However, I removed them (they are plug and play) and put the OEM headlights back in. Same problem. I have checked both low beam fuses (#23 and #25) as well as fuse #40. All of them are good to go. What are the chances that the MFS is the issue? Any help is greatly appreciated!
Check the relays.
I am having trouble finding a good diagram of which relays are for the low beams and where they are located. My search online seems like I am searching through a haystack to find the needle.
It's in your Owners Manual.
If you lost your OM, get a copy here: https://owner.ford.com/tools/account...r-manuals.html I recommend printing it out and keeping it inside the truck in case of breakdown. Check pg 241 of your OM... says Relay 03. There's a picture of your fuse box right in there. Good luck. |
There are no relays in the base lighting system for the low beams, it's all done with switches.
What are the chances that the MFS is the issue? |
Thanks guys for the input. I do still have the OEM manual and couldn't find a relay that would be helpful. There was another thread on here regarding this same issue but I can't seem to locate it. Seems like everything kept coming back to the MFS.
https://cimg5.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/540x435/img_20181230_185713560_ea1988cbc7441c45d377c4781fc 4b84540df27c2.jpg
