Truck will not shift out of park. 2006 ford 150
I've checked the fuse, white release button, bushing on brake cable. Any other suggestions?
Try looking at the linkage on the transmission. See if it will move.
Are you parked on a hill? |
(Post 5241214)
I forgot to add, before you start messing with the linkage, make absolute sure your wheels are chocked and the parking brake is set. I would hate to see you get pinned under your truck.
Good luck. |
u can pull up on the console cover and when u see everything below there is a white tab on the driver side. Press it down! |
