Custom Cluster Question
Old Sep 7, 2018 | 08:59 PM
floydaddict's Avatar
Howdy,
I've been toying around with an "Experimental" mod/project for my truck. my '08 XL has an issue with the oil temp gauge that is now pushing the needle of the oil temp.
I was wondering if its possible to take a '15+ cluster and hook it up (ONLY for the Speedo and Tach) I will remove the screen for the productivity center and put my own screen, running IOT on a raspberry pi, or something and have my own gauges, and information, etc. The layout of the cluster is perfect and I wouldn't have to worry about much else.
Old Sep 7, 2018 | 09:45 PM
interesting idea.
Have you started by seeing if they are even remotely close in size and shape?
Old Sep 7, 2018 | 11:20 PM
Fifty150's Avatar
What about the digital display with the odometer?
This isn't a Mustang II from The 70's, where you can take a drill to the odometer dial and roll it back. Not that I committed odometer fraud. Just heard that it was possible is all.
Old Sep 8, 2018 | 06:16 PM
Just when the person sells, trades, or disposes of the vehicle, usually the title will have a spot for something like: Certify that, to the best of my knowledge, this odometer reading is “NOT THE ACTUAL MILEAGE." with a checkbox.
My buddy has a truck that the odometer doesn't work when he bought it.
Old Sep 17, 2018 | 07:08 PM
I have the software all working. The odometer is going to be an issue I need to work with... but I will cross that bridge when I can.
I am looking though junk yards; and online auctions/etc. to find a dash so I can test to see if it even lines up. I don't want to spend a lot on the cluster till I know if it fits. I would rather put the money towards projects x, y and z
Old Sep 18, 2018 | 12:49 AM
the numbers portion of the odometer can be programmed prior to install
as for the speedometer portion you can get a digital conversion to mirror the output signal of the transmission that the cluster is looking for
