Leveling kit and towing question
Old Mar 27, 2018 | 10:18 PM
Darrenmb's Avatar
Not sure where to ask this as its about suspension and towing, but it is on 06 so i figured here has the most traffic.
truck is an 06 fx4. 5.4 with stock suspension, i am considering a leveling kit to lose the rake, but womdering if it would have any adverse affects whilst towing? Boat and trailer come in right around 5500 lbs and when attached now i dont notice amy sagging, but dont want truck running nose high when i am.towing.... should i leave well enough alone?
Another factor is moat of my towing is just local to ramps etc, but once a year it would be a longer haul, ie from orlando to the keys, so am i wasting my time?
thanks in advance
Old Mar 27, 2018 | 11:03 PM
If you do put a leveling kit in, I'd use a weight distribution hitch and/or airbags in the rear.
Old Mar 30, 2018 | 12:31 AM
Bluegrass's Avatar
Leave it alone.
Old Mar 30, 2018 | 08:59 AM
random155's Avatar
I tow a small 18ft boat with a level kit, no issues.
Old Mar 30, 2018 | 09:11 AM
Dog'em's Avatar
I have pretty much the same set up with an 05 4x4 with a 2.5 " level and 1.5" add a leaf in the rear. Like you I wanted some lift without the nose high rake with the my 5500 pound boat set up. I pull 5 -8 thousand miles each summer for the past 12 years with no issues and a factory ride the rest of the time. The only thing I suggest is good quality shocks all the way around, I went with the Bilstein yellows and couldn't be happier. Bags and specialty hitches are great for heavier pulls but would be expensive and over kill in this case.
Old Mar 31, 2018 | 11:39 AM
Darrenmb's Avatar
Thank you!
