Crown Vic Fuel Pump Driver Module
Old Jun 18, 2017 | 05:52 PM
Bent6's Avatar
25 Year Member
Crown Vic Fuel Pump Driver Module is mounted in the trunk and looks similar to the our FPDM. Do they interchange? Looks like the Dorman number is the same. $10-$20 at a u-pull. Might be a cheap way to fix a common problem.
Old Jun 18, 2017 | 06:03 PM
Good tip if it's true -- shouldn't be any corrosion issues on an older unit if they're mounted in the trunk.....
Old Jun 19, 2017 | 08:45 AM
I would imagine theyre interchangeable, Ford likes to use common parts to multiple vehicles when possible
