Needing new complete struts or shocks only?
this way for years. Will not pass with the spring like it was. Got each Monroe assembly for 119. Doing both sides.
If your springs look good you can just swap them over using the spring compressors like others have mentioned. Using 4 per spring is a good idea since these are truck springs and are much heavier duty than a regular car. I would highly suggest using an impact gun on the spring compressors. If you do it by hand (it can be done) it will take a bit to compress those springs down using manual labor. I used an impact gun and it made it much easier. I have a set of the loaded Rancho RS9000 struts on mine and they went in perfectly. If you do swap springs take your time and position the compressors in a way they wont get stuck when you compress or decompress the spring, I got one stuck and had to compress the spring and reposition and fight it for about 15 minutes.
What size level do you have on there? It shouldn't affect the coil, but those angles aren't great on ball joints, cv's, tierods, etc.
I've got a 2.5" spacer from Fat Bob's Garage. Technically raises the front 3" at the bumper and have had zero issues after 5 or so years. Does something look off to you?
I think I'm ready to pull the trigger. Got it all in my cart, and ready to order. Going with KYB GR-2/Excel-G up front with original coils and KYB Gas-A-Just in the back. Contemplated the Bilsteins but don't want the stiffer ride. Also considered the Rancho RS5000, but read too many negative reviews about Rancho being garbage and making for a rough ride. I think it's the safest road for me, where I don't need anything too fancy. Probably going to be selling my rig in the next year or so anyway. Thanks for the help, all!
So, I attempted to swap out the shocks today. Big mistake. My biggest issue was the fact that my spacer made the strut push too far down, which made my control arm contact the coil. With the rest of the suspension stretched as far as it would allow, the coil still had a lot of pressure on it and I should have gotten some coil compressors just to be safe. My buddy and I proceeded to loosen the ball joint to the point where it was about 1/2" from being loosened completely when the ball joint started rotating with the nut. I can now neither tighten or loosen the nut, even with vise grips on, so there is about an inch of play in the ball joint and I gave up and put it back together. Probably just going to take it over to PepBoys tomorrow and let them deal with it. I have no air wrench to get the nut on the ball joint to go either way so I'm kind of out of options for DIY. Everything went smooth until that point. I did get the KYB Gas A Just shocks on the back and WOW, my truck feels like a sports car on the cornering. Took my stock shocks and put one end on the concrete and took me less than 1.5 seconds to completely compress them. They were completely dead. Loving the rear KYBs so far, but definitely a stiffer ride. Loving the silver monotube look also. I'll keep you posted on the fronts. I've been kicking myself for not compressing the coils before I attempted to take it all apart but I learned my lesson.
Must be that spacer. I can completely remove my coil over unit without removing anything else.
When you said you loosened the ball joint, I assume you meant upper right? When I changed mine the first time the same thing happened. I had air tools though and eventually it let go. I'd check those uppers for wear if they need to be removed anyway. The fact that the uca touches the coil when you're driving means those upper ball joints are getting put to their limits quite often.
You are lucky the strut nut didn't come loose for you. Very bad things would have happened. You absolutely do not change out the the 'shock' part of the strut with it still in the vehicle. You remove the whole strut assembly, compress it with compressors or a strut machine, remove the center nut, then replace the 'shock' cartridge.
I think you're misunderstanding. I never loosened a strut nut, nor would I ever unless I had a death wish. I loosened the nut on the ball joint that connects the upper control arm to the knuckle to see if that would relieve the rest of the compression of the spring, but it didn't quite.
I've done this job before.
I understand the nut your talking about, I had to remove that and use a 2 jaw puller to get it apart.
But, If you raise the truck off the ground with wheel removed, there is no compression on the spring, don't get why you had to "relieve tension?". The weight of the steering knuckle assembly will be pulling the strut assembly apart, not together.
And what I did was placed a floor jack under the lower control arm to just get the weight of the steering knuckle off the strut, and it was easy. At that point the strut assemble has no compression or "decompression" force on it.
