When to change serpentine belt
Hi,
Read several things.
I got a truck, has 138K miles.
Serpentine belt, pulley's and tensioner all original equipment according to the maintenance records.
When should the belt be changed?
The tensioner doesn't appear to have excessive slop in it with the engine running (its not bouncing wildly).
Should I change them all and why?
Serpentine belts are cheap, but I see no reason to change them out more than once every 100K miles. The belt I took off at 100K looked like it would have gone another 100K. I didn't change the auto-tensioner or idler pulleys either, as they appeared to be fine. Worst case is that one breaks and I install a new one with minimal fuss.
I replaced the belt and tensioner. The belt cracking was through the ribs and into the backing of the belt in several places but was was not easy to see when on the truck. belt was pretty stretched as well. Once off it was clear that I was driving on borrowed time.
The tensioner was replaced as well. Total belt and tensioner was about a 10 min job.
Gates belt and tensioner used for both.
It's funny almost, I'm on my 4th belt at 106k. Bad luck I guess.
Replaced belt at 60k, at 70k the alternator pulley siezed and ruined the belt so I replaced the alternator and belt. Last summer, the ac went out and melted the belt slightly, so the ac compressor and belt were changed yet again.
