Help please
Old Feb 12, 2016 | 09:24 PM
lowblackf150's Avatar
Help please
wanted to see is anybody could direct me in the right direction. I have a 2005 f150 5.4 3valve that I have been working on for sometime. got the motor back in and everything hooked up. Now I am getting a drain on my battery. I can hook the positive terminal up and put a test light on the ground cable and the other end on the battery post and it will light up. I disconnected the cable supplying power to the fuse box and the light will go out. I have pulled all the relays in the fuse box and light stays on. Has anybody had this problem and what did you do to correct it. Thanks
