Rear end shudder
Rear end shudder
Howdy yall. So I've got an 08 Lariat crew cab 4wd. Just broke 100k and I've noticed the rear end shudders when I accelerate from a stop but only when I'm turning left or right. Just had the diff fluid changed b/c the dealership I bought it from (Chevy) had regular diff fluid and I've been told it needs limited slip fluid. Any ideas ?
Merry Christmas
Merry Christmas
I fixed my shudder just by adding a small bottle of the friction modifier additive from the dealer. It also stopped throwing a code for the rear speed sensor when I did this. Be warned: the friction modifier is some very nasty smelling stuff. One drop on my garage floor stunk up the whole house!
Easier to quote the correct response than to write it again .....
Merry Christmas
Merry Christmas
Some of the older trucks, such as the 2000 I used to have needed two bottles of FM.
There is a TSB for those older models that said the fix was to replace the clutch pack and shim it 0.010" less preload. i just put an extra bottle of FM in mine and that fixed it. I know it worked fine for 90k more miles before I lost track of the truck.
