Battery issue maybe help?
Old Nov 29, 2015 | 04:36 AM
dadoftwo's Avatar
Ive got an 2008 stx . Interstate battery I bought less than 2 years ago. Everything has been fine. WEnt out to start to go hunting a few minutes ago and..click click. Battery is dead. Lights are low. Interior light is low. But...when I shut the doors and wait for the interior and bed lights to go out they take a long time. LOnger than usual. These lights fade out normally. So is it because my battery is shot that they take longer to power down or is this a sign of a electrical issue thats causing the battery to drain?
Old Nov 29, 2015 | 09:36 AM
First thing I would do is charge the battery fully, then test it or get it tested.
Buying a new battery doesn't mean it is a good one, they are mass produced and depending on where you got it from, it could've been sitting on the shelf for a substantial amount of time with the plates sulfating. Also Interstate was a good brand until they got bought out buy Johnson Controls a few years back. Now it's hit or miss.
If you have a microprocessor controlled charger, it might tell you it's dead from the go because it won't reach an acceptable float charge.
Old Nov 29, 2015 | 10:06 AM
Roadie's Avatar
What voltage is the battery? If it is 12.5, the battery is good and it might be the cable connections.
Old Nov 29, 2015 | 12:03 PM
2008_XL's Avatar
As others have said, get your battery tested. Also get the charging system tested.
Battery should be around 12.8v and the charging system should be 14v-14.5v depending on the temperature.
