Front / Rear wheel stud difference?
Is there a difference between the rear and front wheel studs? I looked them up on napa online and autozone , it should a front and rear option, however they had the same part number and looked to be the same. Reason am asking, is that I tried to replace a broken one on my front wheel and I can not pull it in all the way.
Here are the two studs, Top one is the first one that I tried to use, Got it at auto zone, bottom one is the one I got from NAPA, Both are the same length, only difference that I could see is the thread on the bottom one goes up higher towards the head. Had no problem putting this one in. I guess they gave me the wrong part the first time.
Rear stud removal help
I'm about to replace rear wheel studs on 06 f150 and I'm wondering if when you did your friends (as you mentioned), did you they come out and new ones insert with out any issues. Or did you need to make room for them by sliding the axel or remove heat shield or disassemble the e brake?
Thanks for your time!
