New '08 4x4 owner,misFIRED UP :(
Old May 1, 2014 | 02:48 PM
kip24's Avatar
4.6L 2valve V8
New motorcraft plugs,new Denso ignition coils,fuel injectors swapped (good)
3rd. cylinder still misfires
As far as I know the only thing left is electrical or compression (expensive)
Any input would be great
Thanks in advance,
Kip
Old May 1, 2014 | 05:46 PM
MHOWELL34's Avatar
Is the plug on the connector to plug 3 in good shape, get a volt meter on it or something. Or try to swap a coil pack around and see what it does.
Old May 1, 2014 | 07:32 PM
kip24's Avatar
1/2 the battle is having the right tools
Old May 2, 2014 | 09:29 AM
R1Jester's Avatar
Its been said many times on here but when it comes to coils/plugs its best to stick with motorcraft. For some reason they seem to work best. See if you can get your hands on one for cyl3 and see if that helps.
Old May 2, 2014 | 11:33 AM
Or put one of the old ones back on #3.
Old May 2, 2014 | 11:36 AM
Yep, that's what I would do. Also, make sure you did not crack the plug during installation.
Old May 2, 2014 | 04:29 PM
kip24's Avatar
I swapped the coils around too
Still get that #!@* PO303 code
Guess it's time for a noid light & compression Tester
Thanks Everyone
Old May 2, 2014 | 10:33 PM
Pull the plug, check gap and for any kind of damage.
Old May 7, 2014 | 04:26 PM
kip24's Avatar
UPDATE: compression test verified my nightmare...It's Dead
0/0
My question is ( I want to put a bigger motor in) How much is interchangable from a 4.6 ?
