Challenge for you!
Old Mar 23, 2014 | 08:10 AM
Tumbleweed58's Avatar
Challenge for you!
I recently had a rear pinion seal replaced along with rear end bearings. Just days after the repairs, several things happened all at once. The brake & ABS warning lights came on, automatic door locking quit working, back up lights no longer work, A/C compressor no longer works, sometimes the clock will reset, sometimes the radio presets are cleared, back up warning sensors no longer work...I think that's it.
My guess is that all of this happening immediately following a repair is coincidental; perhaps a computer board or something? HELP!
Thanks in advance!
Old Mar 23, 2014 | 08:32 AM
F150redFx4's Avatar
Check all of your grounds. At the battery frame motor cab make sure there all clean and tight
Old Mar 23, 2014 | 09:55 AM
s27payne's Avatar
How old is your battery? Maybe have it load tested at your local auto parts store.
Old Apr 21, 2014 | 06:11 AM
Checked all battery connections...that wasn't it. Any other suggestions?
Old Apr 21, 2014 | 06:16 PM
wilburzz's Avatar
maybe your mechanic fixed a few other things to get you to go back?
Old Apr 22, 2014 | 07:15 AM
My thought exactly...
Old Apr 22, 2014 | 09:15 AM
FX4Frenzy's Avatar
Did you have your battery load tested?
Old Apr 22, 2014 | 04:40 PM
It might be a coincidence... but it might've happened when you had the work done.
Not saying the shop did it on purpose to get you back... but when they were working on it, the vibration from hammering or impact drivers can do crazy stuff on old stuff.
Old Apr 23, 2014 | 10:18 AM
mtnmanut's Avatar
Thanks in advance!
The 06 went from perfect to next time started-- tach and speedo bouncing, other gauges pegged ,headlites not working , that's what I caught. It was the battery. The truck started fine. turned it off , restarted fine , same problem. New battery no problems. Not saying that's your problem but was mine
