Transmission thermal bypass valve
heres one that's aftermarket but ive read oem gives out at 180 degrees, this withstands past that
http://www.metalbellows.com/Products...FepZ7AodGxgAOg
Would removing this bypass and connecting the lines to always flow fluid through the cooler be a bad thing in warmer climates, say NC? It only really gets cold one or two weeks. I'm thinking about removing it to keep the transmission form running warm if it ever fails. I don't have a transmission temp gauge, so I wouldn't know if it failed.
Decided to log a test drive with my hptuners and noticed my trans temps were high. 200+ the whole time. I'm not ok with that. I'm going to just remove it all together. It's not cold enough in Louisiana to worry about overcooling. I don't see how that's an issue anyway since the tranny fluid is heated up by the radiator.
Btw I checked the cooler lines with air and fluid was flowing fine.
I apologize if I confused anyone, it was really simple to do. I'll post pics if anyone is interested.
I'll post some when get back home Monday. Put about 400 miles on my truck since I blocked the assembly and it's been just fine. The auxiliary tranny cooler is definitely cooler to the touch after its been driven for awhile, and I feel much better knowing i don't have to worry about it sticking closed. I'll hook my laptop up to it and get some real numbers when we get back.
Does anyone have a workshop manual handy? How do you remove the unit? I am considering removing the unit, then just bridging the cooling and return lines, so that the cooler isn't bypassed at all. Haynes Manual doesn't have a page on removing the unit.
