Idles rough. Real rough the whole cab shakes.
2006 ford f 150 67000 mile. The plugs cops fuel filter new driver side cat were done less than 5000 miles ago. Friday it started idling rough just a little not to bad. Then it got worse Friday night. The whole thing shakes violently. I got a p0301 I changed the plug new injector and check the coil. The light hasn't come back on yet. I noticed when I filled it up Friday The gauge did not go all the way to full it went to a little above 3/4 then after ten miles it went to full
mine just starting idling rough as hell as well but has thrown a P0012 code, VCT solenoid. I can reset the CEL and it goes off for a little while but always comes back. Stays off anywhere from minutes to days.
Swap the coil to cylinder number 2.....if the misfire follows then its a bad coil.....and let me just say these coils weather from eBay or Ford are not 100% perfect....that's why I and others suggest if going the ebay route to get a set for a v10 then you'll have a couple of extras for spares...
