coming up on 70,000 miles
Like the title says I'm coming up on 70,xxx miles and i was curious is there any thing you guys do maintenance wise around this milage? Anything i should clean? Like the maf senors or throttle body? Overall I havent had any real mechanical issues only thing i have had to replace was the motor on the back of the transfer case cause the 4 wheel wouldn't engage at all.
Hers what i do...
Engine Management System
• 100,000 Miles Oxygen Sensor Replace
Electronic Fuel Injection System
• Annual Throttle Body & Assembly Inspect, Clean & Lubricate as Necessary
• 6 Months Fuel Injectors Add Redline or BG Brand Fuel Injector Cleaner to
Fuel Tank
• 30,000 Miles Fuel Filter Replace
Fuel Lines
• 5 Years Rubber Replace
Cooling System
• Annual Anode/Cathodic Protection Inspect
• 5 Years Radiator Drain & Flush System
• 5 Years Hoses Replace
Power Steering
• 5 Years Hoses Inspect & Replace as Necessary
• 30,000 Miles Fluid Drain & Refill
Belts
• 4 Years V-Drive Replace
• 5 Years Serpentine Replace
Transmission
• 30,000 Miles Automatic Transmission Fluid Drain & Refill
• 30,000 Miles Automatic Transmission Filter Replace as Necessary
• 30,000 Miles Stick with Automatic Type Fluid Drain & Refill
Differential
Brakes & Assemblies
• Annual Drums, Rotors & Linings Surface Sand, Degrease, Inspect & Replace as
Necessary
• Annual Fluid- Silicone Type Bleed System
• 3 Years Fluid- Conventional Type Bleed System
• 30,000 Miles Wheel Bearings Inspect, Clean & Repack
Wheels/Tires
• 6 Months Tires Rotate, Inspect & Adjust Pressure
Fuel Tank
Fuel Lines
Cooling System
Power Steering
Belts
Transmission
Differential
Brakes & Assemblies
Necessary
Wheels/Tires
