tow mirror help
tow mirror help
i just purchased tow mirrors. i installed them and the paddle light didnt work. does anyone know how to fix problem?
also the mirrors come heated. how do i know if they work?
i have a 2006 ford f150 lariat.
http://s1238.photobucket.com/albums/...3Dphoto2-1.jpg
http://s1238.photobucket.com/albums/...3Dphoto1-1.jpg
http://s1238.photobucket.com/albums/...t%3Dphoto4.jpg
http://s1238.photobucket.com/albums/...t%3Dphoto3.jpg
If you have a Defroster switch on the panel, then the heat should work, as far as the puddle lamp pinout goes, this should help: http://www.tascaparts.com/pages/inde...8&pageid=10207 Someone will have to chime in here as I don't remember which pin needs to be changed out.
Thanks I thinks that helps. Read that and picture from Tasca and moving pins confused me. But I think I got it. If u go by Tasca picture u have to move the 16 pin to 1 pin. And 14 pin u have to add a extra pin and wire and run that to the dome light wire.
Another question is do I have to do the same to both mirrors?
