Info re: Moog Upper Ball Joints
Is that stuff brush on? And will it work well on the brake calipers as well? Just got my moogs and need to paint them and the brakes.
I finally got around to replacing my bj boots with the ones from Energy Suspension and they don't fit. Using a universal part for a specific application seldom works out as intended...
The boots are just too long and the retaining clip doesn't fit the base of the boot so the boot comes unseated during reassembly of the spindle. I'm done with this for now...I've taken the front end apart twice now and I still have a busted boot (but new brakes!) so i'm gonna leave the old boot on there until its time to replace the bj.
Sorry guys...
I used Energy Suspension part# 9.12136
http://www.energysuspensionparts.com...p?prod=9.13136
Actual BJ measurements:
A: 19.5mm - .75" (pin diameter)
B: 46mm - 1.775" (base diameter)
Length: 28mm - 1.125"
Sorry guys...
Just FWIW, and I know this is an old thread, but I never made the assumption the Moog UCA ball joint is replaceable. I saw nowhere in their literature that it was, and nowhere on RockAuto did they mention it...
I thought the only replaceable joints were with UCAs like Camburgs and they use a different kind of joint all together...
