F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2004 - 2008 F-150 (https://www.f150online.com/forums/2004-2008-f-150-80/)
-   -   Won't Start! (https://www.f150online.com/forums/2004-2008-f-150/462193-wont-start.html)
SoCalF150FX4 Dec 15, 2011 04:18 PM
Won't Start!
06 5.4 has factory alarm system, disarmed the truck went to start it and the alarm went off, turned if of tried to start it and "click click". Turned the ignition of and the gauges start buzzing. Cleaned the battery terminals and same thing "click click" followed by the gauges buzzing. Has a newer battery checked with volt meter reads 11.2 at the posts. Any ideas?
kevhead75 Dec 15, 2011 04:34 PM
11.2 is kinda low. I would have the battery checked. Usually they around 12.6 plus/minus a few tenths.
atr04screw Dec 15, 2011 04:37 PM
Battery voltage should be higher than 11.2, so I would try putting a battery charger on it and see if it will start after a good charge. Even though it is a new battery, it might have gone bad. Or it may have something to do with the alarm thinking that the truck was being stolen, and is not allowing it to start now because of that.
SoCalF150FX4 Dec 15, 2011 05:18 PM
Thanks, Ill start w/ the battery and go from there.
mkosu04 Dec 16, 2011 12:18 PM
did you check your fuel pump shutoff switch on the fuse panel? Maybe whatever set off the alarm tripped the shutoff too?
60DRB Dec 17, 2011 08:19 AM
11.2 is WAY low. I know the 0.8 seems like it would be close to OK, but it should be closer to 13 volts. You should be able to jump start the vehicle, but go to some place that can test the battery and charging system (like where you got the battery).
tbear853 Dec 17, 2011 11:20 AM
The symptoms sound exactly like a near dead battery to me. 12 volt batteries as used in vehicles aren't really 12 volts. A fully charged typical 12 volt battery will check out 12.6 VDC or higher.
http://www.marxrv.com/12volt/voltchart1.gif
11.2 is discharged. Maybe you have a steady drain on that new battery or maybe it's defective?
Here is a decent read on batteries and their design and how they vary some in required charge rates just to get you started. It's not the final word however. http://en.wikipedia.org/wiki/Automotive_battery
Here's a downloadable guide in pdf to charging batteries.
http://www.operatingtech.com/lib/pdf...20Charging.pdf
SoCalF150FX4 Dec 17, 2011 02:20 PM
It was a defective battery, the new one reads in at 12.8 v . Crappy duralast they just go bad with no warning, still had the warranty got it replaced for free. Thanks for the help.
ManualF150 Dec 17, 2011 03:24 PM
I replace my battery every 2 years... the old batteries I hold on to and use for jump starts and machinery starts, or portable inverters. I've got a nice Schumacher digital 100 amp charger and I've wired them up to all be on standby (trickle) charge.
