Install a keyless Keypad
Old Oct 27, 2011 | 11:52 AM
jcrew2's Avatar
Ok I have a 07 XLT. I found a keyless keypad door handle the other day. Is it possible and what is involved in adding this to my truck. Thanks
Old Oct 27, 2011 | 12:21 PM
https://www.f150online.com/forums/20...no-power.html?
https://www.f150online.com/forums/20...g-keypad.html?
Old Oct 27, 2011 | 12:24 PM
I added it to my 2005. Of course, you have to remove the door panel and install the bucket/handle. On mine the plug in was there. I had power as it would lock and it would light up, but it would not unlock. The dealer tried to run a program, but it failed. So, they checked out the BSM on the rear wall behind the back seat. They told me they found a loose ground wire, cost me $100 for their work. Worked fine after that.
Old Oct 27, 2011 | 12:27 PM
jcrew2's Avatar
Old Oct 28, 2011 | 08:19 PM
oleman48's Avatar
Hey,I have 08 STX I put the handle in mine. It was plug & play.Took it to the dealer & they pulled the code,took them about 5 min nc.
Old Oct 29, 2011 | 02:29 PM
Neggy's Avatar
go wireless for 72 bucks, a lot less aggravation
Old Oct 29, 2011 | 02:35 PM
05RedFX4's Avatar
Until the battery dies in about 2 years, then you have a 72 dollar stick on paperweight. The battery in those units are not replaceable.
I put one on my wifes 08 fusion, after 2 years I had to remove it cause it died. Her new '11' fusion has it built in like the 150's do, only way to go if you use it regularly.
