2006 F150 air bag light
Old Sep 11, 2011 | 12:08 PM
neilm2534's Avatar
Just walked out to my F150 and it will not start. The airbag light is flashing and there is a constant clicking sound. The key turns but nothing happens and I cannot get the gear selector out of park. When I turn the headlight selector to parking lights the airbag light goes out and the clicking stops but it will not start. Is this just a dead battery or do I have another issue?
Old Sep 11, 2011 | 08:34 PM
NoLongerJeepin's Avatar
Have you tried jump starting it?
Old Sep 11, 2011 | 08:40 PM
avfrog's Avatar
That airbag light may be related to the recall! Your airbag may pop out while your driving! Call dealer immediately and run your VIN!
Old Sep 11, 2011 | 08:51 PM
281cammer's Avatar
Sounds like a low voltage battery concern. All of the conditions you've described can be caused by low voltage. Try jump starting and see if that squares it away. If so replace battery and keep on trucking.
I seriously doubt that, that recall is for the clock spring harness chaffing and causing the harness to ground out. Yes if the truck has the recall surely get it done, but it wont cause a no start concern.
Old Sep 11, 2011 | 09:06 PM
It takes quite a lot of input to the airbag system computer to set off the airbags. Various sensors need to all confirm that the truck is indeed in a wreck. Input from one sensor won't trip the bags to go off.
Old Sep 12, 2011 | 08:05 PM
avfrog's Avatar
Ah... Well that is what my recall paper work and my dealer told me. Not worth finding out the hard way if you ask me!
Old May 23, 2021 | 12:29 PM
Michael Ladd's Avatar
Same issue
I'm having the exact same issues you described, even the putting the headlight switch to parking light to stop the clicking. We're you ever able to figure it out?
Old May 23, 2021 | 01:33 PM
projectSHO89's Avatar
You, know, that was ten years ago....
Old May 23, 2021 | 04:37 PM
Not only that, this member never made another post.
