Replace Front Crash Sensor
if you can locate the connector in here, you'll be able to take the WPT # and/or part # to a dealer, or search Tasca/Google.
http://www.fordtechservice.dealercon...torcatalog.pdf
Just did mine $138(made in Canada part). One local dealer had in stock. Took me a little longer than 3 minutes - likely due to age(truck not me). The connector was seized up and broke apart as I tried to separate it. Then back to the dealer for the pigtail $59. Then had to learn how to heat shrink but got er done. No more airbag light. The sensor body was cracked around the bolt area and the wire harness was corroded inside the wire cover about 3" up. I'd suggest if you do it get the pigtail just in case you need it.
I had to replace the one on my truck in 08. Was only 4 years old at the time with 65k miles. The aluminum oxidized from the steel bolt and it cracked in half. No airbag lights but got it replaced cheap enough.
