Engine Acceleration problem
I have a 5.4 24v engine in my 2004 F-150 that has a humming noise sometimes when I slowly accelerate. It sounds like a four barrel carb kicking in but no extra power. If I let off and accelerate again it works fine. If I push the peddle down farther it passes and accelerates fine. I have cleaned the MAF sensor with spray cleaner no change. I pulled the throttle and spacer off and cleaned with no change. Sometimes the engine will increase 200 RPM's and back to normal over and over again(8 to 10 times). Any ideas before I throw in the towel..
This happened to mine too. Try disconnecting your battery to reset the ECU. It seems to have something to do with the shift patterns and how the truck learns your driving habit. This seemed to work for me.
I've had a Idle air control valve make the same noises. Replaced it with a new motorcraft. Problem solved.
