gryphon or mbrp catback?
Old Feb 16, 2011 | 12:32 PM
DarkShadowSTX's Avatar
The pod will come with your Gryphon, I'm assuming since you said $400 you're getting a monochrome Gryphon and not a CS or CTS (these 2 don't include the pod).
Old Feb 16, 2011 | 01:12 PM
fivespeedsteed's Avatar
yeah im just getting the monochrome. do i need my hex number for it to work since ive updated the pcm or will it pick it up?
Old Feb 16, 2011 | 01:15 PM
When you receive it and install it in your truck, your hex code will be one of the first things that appears on the screen. It will pick it up automatically. I think you can also find your hex code with a decent code reader tool. Since you aren't getting custom tunes yet, you don't even need to know it until you do order them.
Old Feb 16, 2011 | 01:20 PM
rllackey28's Avatar
Originally Posted by fivespeedsteed
better than mbrp? im stuck on single in single out, what would recommend that's better than mbrp?
If going with SISO you could always order a muffler on Performance Peddler and have a shop cut out the stock muffler and weld in the aftermarket. You would be looking at about $150-$200 total for that depending on what muffler you want.
Old Feb 16, 2011 | 01:22 PM
its got a universal magnaflow in there right now. its just not loud at all. and im picky so i have to paint it black with engine paint. i had that done, but it doesent sound much louder at all really. i dont wanna just put a glass pack in there and get all that rasp and crackling and popping.
Old Feb 16, 2011 | 02:28 PM
The automatic retrieval happens 90% of the time....
No big loss though....you can still get it by using the menu functions....
Old Feb 16, 2011 | 03:00 PM
^^ Really? Works every time I've had it out and then reinstalled.
Old Feb 16, 2011 | 03:01 PM
but it will work, thats the important thing, cause i did have the pcm reflashed. as long as it works gryphon it is
Old Feb 16, 2011 | 07:07 PM
60DRB's Avatar
You will notice improved throttle and shifting response with the Gryphon. You will also be able to fine tune any other changes down the road with with the tuner. The exhaust will (maybe) make more noise and nothing more. You decide. Gryphon does not make the engine run lean, but a lot of the "CAI"s do, and the tuner can correct that.
