Turn the key, doors lock. Worst idea ever.
Old Jan 24, 2011 | 09:18 PM
NattyMo's Avatar
Tonight will be the fifth time I've locked my keys in my truck due to this stupid feature. Any way to turn this off?
Old Jan 24, 2011 | 09:21 PM
FX41's Avatar
I'm in the habit of hitting the unlock button every time I hop out of the truck.
StoveTop's Avatar
Turn the key...where? Not sure what you mean...
Old Jan 24, 2011 | 09:23 PM
FX41's Avatar
The doors lock whenever you start the truck.
Old Jan 24, 2011 | 09:25 PM
StoveTop's Avatar
Yeah, got that.
But not sure how the keys get locked IN the truck...on 5 seperate occasions! This has never happened to me so I dont know how common this is!
Old Jan 24, 2011 | 09:26 PM
poolboy1191's Avatar
But it unlocks when you close the door?
Mine only locks when I put it in drive?
I might be different from different years. Mine is an 06.
MTM Ford's Avatar
Prolly does it when he goes to let it warm up. It happend to me in my old truck a few times too.
Can't really help ya. Do you have an owners manual? It'd prolly say somewhere in there.
Old Jan 24, 2011 | 09:28 PM
NattyMo's Avatar
Yea say you go out in the morning to warm up the truck. As soon as you turn on the power the doors lock. I thought this should only be implemented when put into drive or when your reach a certain speed.
Old Jan 24, 2011 | 09:41 PM
FX41's Avatar
Originally Posted by StoveTop
Yeah, got that.
I was talking to the other guy, I think you have figured that out,
Old Jan 24, 2011 | 09:50 PM
DarkShadowSTX's Avatar
I've done this and have no problems with my truck locking. Owners manuals contain a lot of information.
Autolock (if equipped)
The autolock feature is available on automatic transmission vehicles with
power locking. This feature will lock all the doors when:
• all the doors are closed,
• the ignition is in the 3 (ON) position,
• you shift into any gear putting the vehicle in motion, and
• the brake pedal is released and the vehicle attains a speed greater
than 5 mph (8 km/h).
The autolock feature repeats when:
• any door is opened then closed while the ignition is in the 3 (ON)
position, and
Deactivating/activating autolock
There are four methods to enable/disable this feature: One is through
your authorized dealer, the second with a power door unlock/lock
sequence, the third with the keypad, and the fourth using the message
center (if equipped).
Before following the activation or deactivation procedures, unlock all
doors using the power door lock/unlock control and ensure all vehicle
doors are closed.
Power door unlock/lock procedure
You must complete Steps 1–5 within
30 seconds, or the procedure will
have to be repeated. If the
procedure needs to be repeated,
you must wait a minimum of 30
seconds to begin again.
1. Turn the ignition to the 3 (ON)
position, then press the control
three times.
2. Turn the ignition to the 1 (OFF/LOCK) position, then press the
control three times.
3. Turn the ignition to the 3 (ON) position; the horn will chirp to
indicate the driver configuration mode has been activated.
4. Within five seconds, press then the control. Note: One horn
chirp should be heard, indicating the system has been disabled.
Conversely, a horn chirp followed by a honk will indicate the system is
enabled. Pressing the control then the control will turn the
feature ON if it was previously OFF, or OFF if it was previously ON. The
horn will chirp once if autolock was deactivated or twice (one short
chirp and one long honk) if autolock was activated.
5. Turn the ignition to the 1 (OFF/LOCK) position to exit programming.
Note: After exiting the driver configuration mode, the horn will chirp
once to indicate a feature has been activated/deactivated.
Keyless entry key pad procedure
1. Turn the ignition to the 1 (OFF/LOCK) position.
2. Close all the doors.
3. Enter 5–digit entry code
4. Press and hold the 7 • 8. While holding the 7 • 8 press the 3 • 4.
5. Release the 3 • 4.
6. Release the 7 • 8.
The user should receive a horn chirp to indicate the system has been
disabled or a chirp followed by a honk to indicate the system has been
enabled.
Message center procedure
For information regarding the activation and deactivation of the
autolocks feature using the message center, refer to Message center in
the Driver Controls chapter.
Old Jan 24, 2011 | 10:04 PM
06bluemeaniexl's Avatar
well, a viper smartstart would prove useful here.
my smart start can be unlocked from anywhere I have cell phone signal, so if I accidentally lock my keys in the truck and have my cell phone, or can find someone with an android, iphone or blackberry, i'm good.
this has actually saved me twice now, thankfully.
Old Jan 25, 2011 | 12:45 AM
FordHuntinFool's Avatar
yes there is a simple way to fix it, its called "Hide-A-Key"
Old Jan 25, 2011 | 08:51 AM
Big Slick's Avatar
My doors won't lock unless you're moving, like in the list above. Additionally, it's pretty damned hard to lock your keys in these trucks unless you're deliberately trying to. For instance, if the key's in the ignition with the truck off and you lock the door, they will automatically unlock.
Old Jan 25, 2011 | 08:52 AM
SmokeyBear's Avatar
hmm, my 05 won't let me lock the keys in. If the truck is started and in park I can lock the doors, get out, and when I try to shut them they automatically unlock. I have to press the two keys on the keypad to get the truck to lock while running.
Old Jan 25, 2011 | 09:06 AM
kingfish51's Avatar
Have you ever read your owners manual for autolock. Also I have never heard of them locking just by starting. Only happens on mine once moving in drive and over about 15mph.
