2005 with bad injectors
Old Jan 23, 2011 | 08:53 AM
topsy's Avatar
I've got an '05 and it just put out the p0175 code. Just starting to investigate the bad injector scenario, is there anyway to visually identify the bad injectors?
THanks
Old Jan 23, 2011 | 09:22 AM
projetmech's Avatar
curious also. does build date or vin help in knowing if the bad ones are in there? the letter i got says some models are effected but is pretty general.
Old Jan 23, 2011 | 11:03 AM
I believe it's general because all the 05 5.4's are covered.
Old Jan 28, 2011 | 03:45 PM
topsy's Avatar
Since there was a chance the truck would be covered under the emisssions warranty, or the injector warranty, I went ahead and took it to the dealer. It was a bad injector:'05 Supercrew 4x4 5.4, 18,300 miles. No charge for the work, so I'm happy.
Old Jan 28, 2011 | 04:35 PM
That's good to hear your problem is solved....
Old Jan 28, 2011 | 07:28 PM
18k :o Holy low mileage
Old Jan 29, 2011 | 09:20 AM
topsy's Avatar
Got the truck back this morning, running much better ....
Old Jan 29, 2011 | 09:35 AM
Big Slick's Avatar
I thought the letter said "certain" 2005's because the supplier changed mid-year?
I doubt the dealer would bother to check that though.
Old Jan 29, 2011 | 10:29 AM
Only one way to find out for certain if you haven't already blown up, call your dealer service department and provide them your vin.
Old Jan 29, 2011 | 02:13 PM
05BlackFX4's Avatar
exactly...they can tell you right over the phone. Mine just had #7 fail and now a cat went out. As soon as they throw a code take the truck in before it fails.
Old Jan 30, 2011 | 11:47 AM
wheelerfreak's Avatar
I had #4 replaced on my '05 (build date jan of '05), got me worried that another may go out in the middle of nowhere where we often go. I bought another 7 and replaced them as well. It was supper easy to do and gives me a little peace of mind. Now is a good time to replace the fuel filter as well. I also own a low mileage truck and the 7 year extended warranty is only a year from ending.
It has been argued over and over on this site and others that Ford should replace all 8 if one goes out, but it is their choice to make...
Old Jan 30, 2011 | 11:52 AM
Big Slick's Avatar
What was the part number you used for the replacements?
Old Jan 30, 2011 | 01:18 PM
StoveTop's Avatar
The most recent part number I have is 5C3Z-9F593-DC. After all these threads recently, I am placing my order later tonight.
Old Jan 30, 2011 | 02:28 PM
I don't remember, I bought them online. They were supposed to be the OEM supplier...
