Truck shutting off
Old Jan 5, 2011 | 05:03 PM
david_9342's Avatar
Truck shutting off
Usually happens in the morning on my way to work I stop at a light or in a drive thru and when I take off a couple seconds later the truck will die or when you press the gas does nothing and a wrench lights up on my dash. But i can turn off the truck and restart and it drives fine.. Has anyone had this problem
Old Jan 5, 2011 | 06:39 PM
2stroked's Avatar
Go to your local auto parts store where they read codes for free. See what shows up, then post back.
Old Jan 5, 2011 | 06:53 PM
david_9342's Avatar
Read it with my brothers scanner and nothing
Old Jan 5, 2011 | 07:05 PM
MTM Ford's Avatar
It's something to do with your Electronic Throttle Control. Take it to a Ford dealer and have them get the codes.
Old Jan 5, 2011 | 07:41 PM
Clean the TB
Clean the MAF
Change the fuel filter.....
Old Jan 5, 2011 | 07:48 PM
david_9342's Avatar
fuel filter is about 2 years old. what can i use to clean the maf and throttle body?
Old Jan 5, 2011 | 07:51 PM
check your FPDM as well
MTM Ford's Avatar
There's a special electronic cleaner to use for the MAF. CRC Electronic Cleaner is pretty good. I also use CRC Throttle Body cleaner. Do NOT use anything other than Throttle Body Cleaner on the Throttle Body as you can take off the coating.
Don't use anything but MAF cleaner because anything else can leave a film on the sensor.
Old Jan 5, 2011 | 07:57 PM
Fuel filter is to be changed every 15k...
How to clean the TB...https://www.f150online.com/forums/ar...ttle-body.html
How to clean the MAF....https://www.f150online.com/forums/ar...005-5-4-a.html
