Bed Bounce Solution?
Old Jan 5, 2011 | 02:15 AM
  #31
tbear853's Avatar
The damper is a big chunk of cast iron, maybe 12 or 14" long, a few inches wide and a couple 3 inches tall, mounted with what looked like two rubber isolated bolts to the top side of the left frame rail very near the rearmost cross member. It's up on top, don't hardly see how it would affect a hitch installation.
If I think about it I'll try to get a good picture of it tomorrow.
I must say, mine don't act funny going down the road?
Like i said, I've never dropped my '07's tailgate to notice any vibrations though I don't doubt some would be generated. The video didn't look all that bad to me though.
Anyway, the bed bolts are tight you say and short of a major frame seperation / break ...
... don't see how could be much else but normal?
Old Jan 5, 2011 | 08:39 AM
  #32
agood1's Avatar
Originally Posted by 61 falcon
not all trucks are the same. some trucks shake more than others. I'm just passing along info from my experience working with this concern in the dealer when the 04's came out. bottom line is added weight to the rear of the vehicle after the axle helps reduce the shake. its not that there is something wrong with the truck. its stems from the design of the frame and chassis, this is info i got from ford tech line and our field engineer. what you need to do is have someone drop your gate open like you are doing in the video while you look for the origin of the shake. is the suspension holding still and the tires are bouncing on the side walls, is it the leaf springs or shackles that continue to move, are the shocks moving. something has to be moving, its a game of elimination. put the rear of the truck on jack stands, under the axle. weight of the truck on the axle, tires off the ground. does it still shake, this will eliminate tires, have a friend stand in the bed while you open the gate, is it still there. my truck has done this since day one and 85,000 miles later it still does it and no ill effect on the truck. i accepted its a characteristic and left it at that. if you feel otherwise, thats OK. i have talked with alto of f150 owners that felt that way as well. spend some time and see if you can resolve your shake issue. you could end up being the one that helps other solve their shake concern as well.
Thanks for the good suggestions. I did this a few months ago, and I found with the truck sitting on the ground the vibration was all the way into the leaf springs. I could see the springs shake when the tailgate was dropped. This carried all the way up the frame and to the cab. The tires and axle were solid and did not move. I originally had load range E tires on this truck with 80psi in them....I changed to load range D with 35PSI in hopes of correcting some of this shaking....both sets of tires demonstrated the same result.
Old Jan 5, 2011 | 07:22 PM
  #33
tbear853's Avatar
Here you go ......
Originally Posted by DanBBP
I was ordering a hitch for a friend on his 07 screw and the salesman asked if the truck had a vibration dampener, I asked what the @#*l is that! he said in 06-up Ford installed a dampener on some of the trucks! so I asked where would it be so I can check! He said in the rear by the frame, you will know it when you see it! and ive noticed alot of different variations of factory hitches on same trucks but different years, this makes me think that thier is some kind of dampener on some trucks but I have yet to see one!
I do know this isnt anything new to the auto industry because in the 60's and 70's vibration dampeners where in alot of full size 4 door sedans, they where in the trunks!
something to think about!
Pics of the weight as it sits on top of left frame rail near extreme rear of truck under a 2007 Ford FX4 Scab 6.5 Flareside.
Looking straight up from ground, outside of frame rail, you can see the rear shackle and rear of left side rear leaf spring in left edge of picture to the right is the rear underbed cross support.
This picture and the one below it were taken by just holding the camera up inside the rear side and aiming.
Looking towards rear of frame from behind left rear tire
Looking across at front end of weight from same area behind left rear tire.
There are only two of these bolts going through rubber isolated mounts.
No doubt but that the rubber density and sleeve length and bolt torque are all very precisely tuned to perfection because ...
... I don't have any bed shake.
I tried it.
Must be a Styleside malady?
Old Jan 5, 2011 | 08:56 PM
  #34
agood1's Avatar
Thanks for the pictures. If that is mounted to the top of the frame rail, then I know it is there to solve my problem. The physics just make sense. Now the question is, where can I get one and will it work on my truck.
Old Jan 5, 2011 | 11:08 PM
  #35
tbear853's Avatar
Maybe it will. I looked, there is none on the right side, just the onne on the left. Just two bolts. I was poking some fun at the Styleside folk above in my last post, but even as late as June 2007 Ford was putting them under some trucks still ... at some costs ... for some reason.
It's certainly big enough to dampen harmonics.
Any "Pic-N-Pull" yards near you.
It's certainly worth a try?
EDIT:EDIT:EDIT:EDIT:EDIT:EDIT:EDIT:EDIT:EDIT:EDIT: EDIT:EDIT:
Just because I'm such a nice guy and all, I just went out in to the winter night across that cold driveway into that cold carport shed and with my genuin 2 D cell Maglite (LED) I scoped out a little more.
That weight is near 5" or more wide .... more wider than I first guestimated.
Also, look in the lower picture of the three in my last post. See that "diamond" shaped hole there on the left in line with what is the front bolt holding that weight on? You will have to go through that hole with a medium deep socket and ratchet to secure the nut, ... maybe a swivel and ext and keep the ratchet outside ... and use a wrench with offset to latch onto the bolt head up top.
I'm guessing about 15mm. Take a set of 14s and 17s to be sure .... but I'ld say it's 15mm.
The same goes for the bolt head of the rear bolt, but the nut inside the frame rail can be easily accessed through the rear iopening of the frame rail once the spare is out of the way I think.
All real easy if the bed is off as well. I think once the nuts are off that it'll rock over and the bolts come out. When putting back, I'ld almost try putting bolts in from inside frame rail and nuts on top?
My guess is it's gonna weigh some more than 10 pounds.
Old Jan 6, 2011 | 06:39 AM
  #36
Windsor's Avatar
That's the same dampener I have under my 2008 crew cab. The pics I've seen of the dampener used on the 04s is different, but from what I can understand was in the general location.
Old Jan 6, 2011 | 09:02 AM
  #37
agood1's Avatar
Wonder if Ford only installed these on specific wheelbase trucks......mine is a SCREW with the 5.5" bed.
I have been looking thru online parts houses with the parts diagrams, and I cannot located this dampener in any of the diagrams. I even tried using TBEAR's truck as the spec, still no luck.
Old Jan 6, 2011 | 12:07 PM
  #38
Windsor's Avatar
I found the part(s) on FordParts.com for your truck. For some reason Tasca Parts is only displaying data for Volvos and Mazdas. Go tto FordParts.com, select 2006 F-150 and then select the "Suspension" category and then the "Suspension, Springs and Related Components" sub-category. I found the dampeners on the last page of the items in that sub-category category and it's chassis and build date specific. The component for the later builds are a lot cheaper than the earlier builds.
Old Jan 6, 2011 | 01:50 PM
  #39
agood1's Avatar
$826.00!!!!!
Holy cow
Old Jan 6, 2011 | 02:30 PM
  #40
agood1's Avatar
Here's a TSB on this issue....too bad I am out of warranty....can't swallow $826.
http://www.phila.gov/fleet/Warranty%...sb08-24-02.pdf
Old Jan 6, 2011 | 09:33 PM
  #41
tenzip's Avatar
$826.00!!!!!
Holy cow
WHAT?
For a chunk of steel?
Is this the magic steel with fairy dust, or what?
If someone on here has one, and is willing to take measurements, I'll see if I can get one made at work for you.
Otherwise, grab a 10lb barbell weight, some pieces of rubber, and a bunch of long wire ties, and strap it to the frame up under the bed to see if it helps any.
Old Jan 6, 2011 | 09:41 PM
  #42
DarkShadowSTX's Avatar
Bed bounce? Check out the Tundra.
http://www.youtube.com/watch?v=EWjTbiYo3x0
Old Jan 6, 2011 | 10:05 PM
  #43
DanBBP's Avatar
That vid is the first thing I thought of when this post came up!
You thought your bed bounces check out the trucks in that vid!
IMO Ford put out that vid after they received many complaints and came up with the Dampener thing then had to show that they dont have bed bounce problems!
No Dampeners/ No bad bounce on my truck!
Old Jan 7, 2011 | 01:47 AM
  #44
tbear853's Avatar
Cool
$826.00!!!!!
Holy cow
Oh dear me ... ... that's just effin great!
Now I feel like I should be sleeping under the truck with a shot gun in hand.
If I was wanting to try it, I'ld be scouring a junk yard. I'ld say a Styleside wrecked would be easiest to get it out from under. No hitch or spare would make it even easier.
Here's FORD 6L3Z-5D008-B DAMPER ASY (Package of 1) for $129.92 fits 06-08 according to the link above. The one for the 04-05 is 4L3Z-5D008-AA, I didn't see it.
Old Jan 7, 2011 | 06:25 AM
  #45
Windsor's Avatar
agood1 did you see the build dates info for the various parts? The early 2006 build was 4 times more than the dampener on trucks built after December 2005. That's probably list price too. Check with the guy in the Tasca Parts thread and see what you can purchase it for. If it were me and I had the earlier build, I'd start a junkyard crawl.
